Confused about marine Fridge's,
2
Hunter 33.5 Boca Raton
Ok, can someone tell me what the difference is between a marine fridge and a small compact fridge from a appliance store. well the obvious, Price!!! I am a little confused, I could pick one up from an appliance store ( a 1.7 cu.ft) for around 50.00 to 100.00, but a Norcold about the same size is around 600.00 +. I know that the Norcold will run on 12VDC, and possible better insulation, but come on. I get a 120V on my boat when plugged in on shore power,or get a inverter to get my 12VDC. is there such a reason for such the price difference? funny, for the price of a small Norcold, i could get an awesome fridge for my house, stainless steel as well!!!! confused!!
7,733
Alden 50 Sarasota, Florida
better get some bigger batteries
at a cost which may exceed the price difference in refrigerators which typically draw around 5 amps at 12VDC. That would equate to a 110VAC compressor draw on an inverter of 60 watts... By comparison, a small "dorm room" refrigerator we have on the porch draws 800watts which at 12VDC would be around 70amps through an inverter.
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
Good answer from Don...
If you think boat parts are expensive, wait till you buy something for an airplane.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
There was a thread
in the archives about using a small bar fridge (120v). I believe the owner put the cooling unit into the existing cooler in his boat. I took a quick look and couldnt find it. I also saw a picture of a 34 not too long ago with a larger- looked to be 4 ft high or maybe a bit more - set up in the place of the existing cooler. It was even stainless steel. Now that would not help the built in H34 starboard list!!.
Daryl
Diference = Price
The last Norcold I worked on had a compressor that operated on 20 volts AC. There were transformer / inverter electronics built in the unit to make 20VAC from 12 VDC or 110 VAC. The fridge cooling is basically the same. I've taken many dorm fridges apart and installed the guts in boat ice boxes with great success. Putting these parts in a well insulated box I find they don't run very long or often. Hooked to a pair of golf cart batteries through an inverted you can always have cold beer for under a hundred bucks
Jun 2, 2004
5,802
Dorm fridge works well.
The previous owner of my boat removed the stove/oven and inserted a dorm fridge. I think something must be wrong with Don's porch fridge because mine is rated one amp at 110v AC. It runs less than half time and uses about nine amps of 12v DC. So I round up and figure about 5 amps per hour. I also have a 12v Adler/Barbour in the icebox that is not much better than that. I leave the dorm fridge and the AC on all of the time. The beer and pop is always cold when I get to the boat.
Dec 2, 1999
15,184
Dorm frig at the dock only.
If you only want to keep your beer cold and the mayo from spoiling while you are not around then the dorm unit can do it for you. I have seen the guts pulled out of the refrigerator and installed in the icebox which makes a nice installation if that is what you are really looking for. On the other hand if you want to spend several days out sailing and anchoring you don't really have much of a choice. You will need to look at a 12vdc unit. Some of these units are very low battery consumption (less than 1 amp/hr). This is dependent on how much insulation you can get into your box. We ended up getting a Isotherm SP unit. It uses NO FAN but the compressor pump the coolant thru a fitting (sink drain) in the hull (like a keel cooler). These units have a couple of advantages. The first one is that they are totally water cooled. The coolant is cooled to the temp of the surrounding water. The unit does not pump heat into the cabin area and there is no fan to listen to. I have not actually measured the actual power consumption but the factory reps are quoting somewhere between .8 - 1.5 amps.
May 24, 2004
7,228
CC 30 South Florida
To make the comparison fair you have to
consider the cost of the inverter and its installation. For a dorm refrigerator that consumes around 1 amp at 120V you will need at least a 1200 Watt inverter with soft start. A non-marine inverter will run you $150-$200. An inverter that size will need to hard wired with heavy gauge wiring, a #2 or #3 depending on the roundtrip distance between the unit and the batteries. A 150 to 200 AMP fuse will be needed to protect against fire. Between the heavy gauge wiring and the fuse expect to spend another $100. So now you will have an $80 refrigerator with a $250 inverter for a base total of $330-$380. It will still run you less a marine unit and the inverter may be used for a TV or another 120V appliances. Anticipate that the power consumption will be approximately 3 amps per hour. The compresor will only cycle for about fifteen minutes of each hour. This will vary with the starting temperature of the fridge or the ambient temperature of the air. Some of the new units don't have a fan and are quite silent. By contrast a marine unit will consume around 1 amp per hour. The marine environment is harsh and although these dorm fridges are very reliable the inverter may not last as long unless you get a marine inverter but now you are talking $450-$500 plus plus wiring and fuse. There is no doubt that if the boat already has an inverter the addition of a dorm refrigerator is the most sensible way of doing it.
Feb 29, 2008
3
Hunter 320 Emeryville (SF bay)
This is sounding even better
Benny, 1amp at 120V is 120watts... That's a pretty small inverter requirement! Its going to draw 10+amps(+startup) from the 12V but that's not a problem, you just need enough battery capacity aboard to keep it going as long as you want. But, its already set up to run back at the dock. Daryl, So the marine frigs actually run on AC and have an inverter already? I have a small refrig that I want to get around to stripping and installing in my icebox on my H320, this project is sounding better all the time! Gary H320 Time Bandit Emeryville, CA
May 24, 2004
7,228
CC 30 South Florida
Gary, read the posting and check your formulas.
If you can run a dorm refrigerator on a 120 0r 200 Watt inverter you can probably walk on water.
Feb 29, 2008
3
NO but..
HI Benny, I wouldn't try that but I do have a 1500watt(3000watt surge) that should work fine. It cost $85 as I recall (Costco Xantex, not marine but..). I just checked, my "dorm" fridge (Sears, actually taller than the smallest dorm type) only takes 0.9A at 120V. That's running and there is a big surge at start up I know (does anyone know how much that would be?). Gary
