A
Al Hansen
I own a 1997 383 Oceanis, with vertical spillover freezer/fridge. After a short period of use, the spray on insulation oozes water, which drips down (behind the cabinetry), also the compressor has to work overtime because of heat conduction thru the water. It appears to me that the spray on insulation was not closed cell or has broken down allowing condensation to develop, hence the water. I've cut two 6" holes in the front panel to figure out the problem and also to get towels in to dry area. Presently, the only solution I see is tear out the cabinetry that encloses the freezer and replace the insulation. Beneteau makes good cabinetry and this appears to be a major job, might need dynamite. Has anyone out there got a simpler solution? I would sure like to solve this annoying problem. Sincerely,Al Hansen
