Hi,
I have a Hunter 260, 2002 and have never had any leaks to date. This weekend it poured hard for about two hours and I noticed a very small trickle or drip of water running down the right front bulkhead. It appeared to be comming from the front right corner of my starboard window. (One of the life line stantions is almost directly above the potential leak area.
The next morning I noticed a bit of condensation in the window, the size of a quarter. When viewed from the inerior the condensation was not able to be seen?? The day became very hot and several other small spots of condensation appeared, again only seen from the outside view of the window. They could not be seen when looking from the interior. This is the spot near the leak.
I think the culprit could be the stantion area because the exterior seal of the window looks to be in excellent condition. The very top of wher the stantion is attached looks to be an ideal area for water to collect.
Any advice is appreciated, where to look, seal and what to seal with??
I know this sounds wierd but it is true.
Thank you,
Earl Keim II
Thank you,
Earl Keim II
