G
gagews
I have Catlina 1973 22' that I bought last year, lots of fun. The begenning of this summer, have been working on it as it has been out of the water(Pacific Northwest).Here are a couple of concerns that I have. 1. The pin for the keel has a gallon of epoxy to keep it in the unlock position. It must have been leaking and was a quick fix for somebody. I have not had a blow down, but if happens, I've heard the keel can fly back into the haul and sink the boat. Is this true?2. There is this valve that can be closed with a plastic T fitting on top. Water goes from the cockpit into it and then the rear of the keel through a tube. It was clogged really bad, so as I was twisting off the plastic T fitting on top, the valve moved about an inch. It's not loose, but with enough force, could move it. I am going to use double hose clamps on everything, but can water come up and sink the boat from that location? These boats are great, but there are some design concerns that I worry about.Thanks, gagews
