compressor goes on and off
V
Vasco
I have 12v holding plate unit with a Danfoss compressor. The compressor will run for a minute or so and then cut out. The air cooling fan continues running. It will start again and then cut out again. Over and over. Initially I had a problem with a poor ground and the whole unit was shutting down (low voltage, beeping ) I fixed that,(new wiring) there's lots of voltage (no voltage drop) and now I have the compressor shut down problem. The freon (R12) is good I think (was frosting up nicely on the weekend). The compressor is not overheated ( I can hold my hand on it for ever without burning). Is it the control module and is this problem coincidental or related to the earlier low voltage problem. (the low voltage problem was intermittent over a week, I used the wire jiggling method before I finally corrected it). Is it the compressor? There is no amperage spike when it starts - just the usual 4 amp draw. The unit has run flawlessly for 15 years. I am at the end of my limited knowledge. Help!
Jun 7, 2004
944
Birch Bay Washington
Control unit
I have had two of these go bad exactly as you describe. This is a famous problem. It should be an easy fix but there is no repair information readily available. It is somebodies private source of income. You can get a repair for about $100 or so from an outfit in Florida. Another proprietary fix for a routine failure - planned obselesence, "marine business",... I will be shopping for a different brand next time mine goes bad.
Jul 14, 2004
1
CONTROL MODULE
The outfit in Florida is miller marine 904 388 3690, The module new is # AB 3016 and is available from NORTHLAND SUPPLY CO. QUEENSVILLE ONTARIO 905 478 2244
