new opinion
Under the floor there is a longitudinal frame. I applied a 5 ton jack under it and it wouldn't budge. Therefore, I have to assume anything resting on it, like the compression post, isn't going to move it either, even thought the movement is in the other direction. To test it, we loaded down the mast by tightening the shrouds and stays and it didn't move. So:I looked at the ceiling and found that the way the boat was built, in my opinion, was that the ceiling was lowered onto the boat, then the deck or the ceiling was mated to the deck, and that was then mated to the hull. Therefore:the lowering of the ceiling inthe general vacinity of the compression post leads me to believe that is the problem. Also of note: I cut away two feet of the bulkhead, after taking careful measurements of the ceiling height, wall angles, withs, etc and nothing. After removing the lower two feet, nothing was different. Therefore I have to assume the bulkhead does little in holding up the ceiling, with the cave3at:The whole boat flexes. That is why Irwins are known as poorly built. The bulkheads maintain some hull integrity. My plan is to undo the shrouds and stays and then jack up the ceiling or compression lost and place flat, 4 x 4 aluminum shims under the comp post or above it. As for being an amateur, Yes I am. That said, I see this project and not being to difficult and well within my capabilities.
