In Process - Mast Down
I am currently in the process of replacing the compression post on my '94 H27. I am doing it in the water with the mast down. I chose to drop the mast because I was worried that with the stays loose, the mast would not be properly supported in the Texas winds we have this time of the year.I am very glad that I have the mast down because of what I have found after diging into this to include: rebuilding the support between the hull and cabin floor, replacement of the cabin floor in the head area, replacement of the compression post, replacement of the bulkhead between the head and salon, and rebuilding of the cabin top around the mast step. All of this is required because of water damage from leaks where the wiring comes through the mast step. Some of the issues were know from the pre-purchase survey, but the true extent of the damage was not.At the same time, I am taking the opportunity to rewire the mast, replace the steaming light, rewire the bilge pump, freshwater pump, mast to keel ground, install new CD player, replace sanitary and fresh water hoses, rebuild the cabinets, and whatever else comes up.Steve's comment is right on... Do it RIGHT, do it ONCE!Search the archives on compression post and mast step and there is a lot of good info out there. If anyone faced with this issue would like to take this offline, feel free to contact me throuth the owner's directory.ChuckS/V Following Sea
