C
CLIF
Well boy here it is ! How bad is it?I have a 73' oday 23Last weekend it was cold and I decided to replace the wall between the v-berth and cabin. It was rotton because the previous owner didnot like to repair leaks. I unscrewed the wall at the base of the benchseat and side of the hull and it would not slide it out of the groovesbecause of this 2x2 piece of wood that was what I thought was a corner piece. As I hit it with a hammer I noticed it was under presure and so did mywife. I hit it a few more times and the wife asked if I still wanted todo this. I said in a few more hits I will have it. Well, I did and the cabin top sunk about 2 inches. I did not know if I need to abandon ship.( I forgot, the mast still up and tension on the shrouds)After 3 hours of jacking, cutting the new wall to try to get it to fit.I have given up and now think of sinking this ship.....No really but I'm stumped and need help.1. I guess I need to take the mast down. It is not hinged, so I guess the mast slides over something at the top of the cabin to hold itin place? 2. Most people say that the chainplate has 4 bolts coming thru the top ofthe cabin. I have only two, is that a problem?3. Once I get the mast down how much easier will this be to jack the cabin ceiling up?4. Will the hull come back to form. I cut what I thought was a duplicatewall from the orginal and it won't fit.Thanks for the input..Clif
