Jim
I have a 1980 Hunter 30. There is a piece of plywood approx. 1 inch thick supporting the post directly under the sole which is then supported by a piece of I beam between the keel and the plywood. The post is a little off center of the keel, thus the need for the plywood to bridge the difference. My problem is the plywood has deteriated because of moisture and is failing. How do I go about replacing it.
