My compression post fills with water. After a few days of rain I can siphon up to a gallon of water from it. For some reason it doesn't make it to the drain hole at the base of the post. My counterweight seems to be frozen. I'm wondering if the counterweight is preventing the water from making it's way to the bottom. There is a grounding wire from the mast that makes its way through the post and is grounded to a keel bolt. Does the wire run through the counterweight? Are there holes drilled in the counterweight that allows water to pass through? If so are the holes clogged? Any help is appreciated
