A crack in the floor of my 1980 C22 needs repair and any help would be of great value.At the base of the compression post where the floor raises up from the center isle walkway I have a crack that is 3 inches long by 1/4 inch wide. When looking in the forward dinette seat locker the fiberglass that spans from the seatback bulkhead to the hull is collapsed and fractured. This fiberglass span was so thin that it appeared to be decrative rather than structural. There is a 3 by 3 inch wood beam under the compression post that has been built in but it stops well short of the hull. What stops the floor pan assembly from flexing down towards the hull pan? It is this flex that is cracking the floor. Any help would be great.I have a good bit of fiberglass experence and a good shop to work in so I want to make a solid repair.Thanks, Ray
