I have just take out the compresson post of a lancer 28, what i found was a compression post, with two plates either end, both plates drilled to take bolts, but the only bolts, holding the mast shoe, the other end, which rested on the keel, had no bolts holding it, and was just sitting. Their were small squares of plywood, between the compression post and the keel, and between the compression post and the coach roof.
Should the post be bolted into the keel, seems to me it should.
I would also like to fit a vhf antenna, but i want to run the coax to the mast step, then have a fitting, where i can hook the cable from the mast to, and disconnect it, when i take the mast down, but a cant find a fitting like this, any ideas.
