Hey everyone,
I'm working down the project list on my '83 C30 over the winter. This boat was completely refit by a previous owner and mostly in good shape. It has a few issues that I'm trying to improve, one being the well known compression block in the bilge.
The original compression post between the deck and floor pan has been replaced, and the new one looks good from the outside. I drilled into the compression block in the bilge, and it's quite wet. I've read up on this fix quite a bit, but still have a couple of questions.
1. Can I replace the compression block with the mast still standing?
2. Can I remove the aft side of the compression post to inspect inside and look for a leak point? Again, with the mast standing?
3. The plywood in my bilge is collapsing. This plywood extends under the compression block, correct?
Thanks again!
Thanks again!
