J. R. Setser
I recently purchased my new Ritchie BN-202 bulkhead mounted Compass. One of the primary reasons was that I have seen other Hunter 26 and 260's with a similar compass mounted on the port bulkhead. The instructions for installation mention the need for a fairing block if the compass does not sit vertical when mounted. However, at no time have I seen a block used on another boat. How sensitive is a bulkhead compass when installed on a 26 or 260 and what is the best way to correct deviation. Reading the forum archives, and online documentation, some say to remove the compensation magnets if not on a true vertical plane, how would you correct with no magnets? Any tricks or tips on compass installation and wiring sure would come in handy. TIA for all the help.J. R. Setser
