Compass hole
A hole saw is the best. The good quality large ones are kind of expensive. You might could borrow one from an electrican or plumber. Make sure if you do that it is sharp. If you haven't used a large hole saw like this before, practice on plywood first to make sure that you don't scar up your boat or wring off your wrist. You could also use a roto-zip type tool, but it requires skill and care to avoid a very unhappy result.Good luck,Joe C. in NC'01 H260 Windward Passage
