Some brands used a light weight mineral oil and most others used Odorless Mineral Spirits. You don't want to used the wrong fluid as it can change the design characteristics for damping. Put some one your fingers and feel them. The put some mineral oil and mineral spirits on your fingers and do the same. Pretty easy to tell the difference between mineral oil and spirits.
With many compasses flip it over and remove the plug and re-fill with Ritchie Compass fluid. You may have a bad o-ring on the drain plug or a bad o-ring sealing the globe.
Until 2001, Ritchie compasses were filled with a high quality odorless mineral spirits. Ritchie now uses a fluid called Isopar L® that has similar properties but some added benefits over odorless mineral spirits. These two fluids can be mixed together.
Ritchie began using Isopar L as dampening fluid during 2001. This fluid is a high-purity isoparaffinic solvent very similar to Odorless Mineral spirits.
Ritchie changed to this fluid because it has a higher flash point and conforms to most of the world's shipping regulations. It is important to note that some other manufacturers use Isopar M as their dampening fluid. I know ISOPAR M should not be used in Ritchie compasses but don't know about Plastimo. Hamilton Marine sells Isopar L/ Ritchie Compass Fluid but any hardware store sells odorless mineral spirits.
Ritchie also suggests: "Dampening Fluid - Be sure to subject the fluid to a vacuum equivalent of 28 inches of mercury for a minimum of 15 minutes before sealing it in the compass. This step prevents the formation of a bubble in the fluid due to temperature changes."
An old trick to get around that, which often works very well, is to stick the Isopar L or Odorless Mineral Spirits in the freezer for a while then fill the compass with it.
