A
		Anthony Bavuso
Greetings,I just bought a 1985 Hunter 25.5.  The previous owner installed a stereo system with bulkhead mounted speakers.  Unfortunately one speaker is about 6 inches below the bulkhead mounted compass.  It is a fluid damped card type compass.  Unfortunately I did not note during the sea trial that the compass always pointed north!I am pretty sure that the speaker is putting off enough of a magnetic field to keep the compass pointing north.  I brought a hand compass on board and observed the same behavior as the mounted compass.So my question is how do I fix the problem?  Can I use a correction magnet placed in the right location to offset the field produced by the speaker?  Can I buy a special type of speaker that will not interfere with the compass?  An obvious solution would be to move either the compass or the speaker but doing either would leave large holes in the bulkhead and in addition there is no other place to move them to.Thanks so much in advance for all your help.
