Compass advice for a small boat ?
307
Seafarer 29 Oologah, OK
I'd like to get a compass for my boat. I bet there are a lot of good ideas and advice here.
It needs to be small but easy to read while hiking out. Preferably something which could be installed on the main sheet block post or just abaft the mast (I've attached a couple of pictures to hopefully show the configuration of the cockpit).
914
Boston Whaler Montauk New Orleans
A handheld with a lanyard to go around your neck might be what you need. Otherwise, if you have an Academy Sports store, go check out their marine products. They usually have several different kinds of compasses. Depends on your budget and how much work you want to do installing it..
Joe
Jun 1, 2004
8,328
Sorry west marine is not known for their small boat expertise...I would suggest you try http://www.mauriprosailing.com or http://www.apsltd.com
Here's a flushmount option from Annapolis Performance sailing:
Plastimo Mini-C Compass
The Plastimo Mini-C has a gimballed magnetic cell which makes it adaptable to any location on board, vertical or horizontal. Installation is easy - the Mini-C is simply flushmounted. 2-3/4 inch apparent card diameter with two luber lines. Available with either a black or white flange.
PL31318Mini-C Compass - BlkPrice: $96.78 PL31341Mini-C Compass - WhtPrice: $96.78
Here's a bracket mount option from Mauri Pro Sailing
[FONT=Verdana, Arial,Helvetica][SIZE=-1]RITCHIE EXPLORER COMPASS - BRACKET MOUNT BLACK[/SIZE][/FONT]
[FONT=Verdana, Arial,Helvetica][SIZE=-1]Quantity in Basket:none
Code: RITB51
Price:$49.30
Shipping Weight: 1.00 pounds
[/SIZE][/FONT]
My ultimate solution, where budget is not considered (Again, from Mauri Pro)
[FONT=Verdana, Arial,Helvetica][SIZE=-1]Tacktick Micro Compass[/SIZE][/FONT]
Code: TACT060
Price:$449.00
Shipping Weight: 2.50 pounds
[/SIZE][/FONT]
Jul 28, 2010
914
That micro compass looks to be your ticket, since you'd likely be hiking out on both sides of the boat.
Joe
Jun 1, 2004
8,328
Hand held compasses are not for steering, they are for taking bearings on other objects. Both Potomac Daysailer's hands are extremely busy when sailing his ultra cool dinghy so it's much too inconveninent (or inaccurate) to mess with a handheld or wrist mount. He needs an easily visible compass that is fixed to the boat so he can check his heading with a quick glance.
The digital style compasses (Tacktick) are popular with racers because they memorize the previous heading. That allows the skipper to more easily determine wind shifts.... otherwise, with a magnetic you must use your memory. For tactics, they may use a handheld compass or use predetermined angles drawn on cards affixed to the boat that allow them to determine laylines, judge whether they can pass or not, and know whether they're ahead or behind the competition.
I forgot to mention earlier than another solution is to purchase two small flushmount compasses, such as the type kayakers use, and put one each rail. I, myself, would prefer one large compass in the middle that could be seen from every part of the cockpit. That's why I like the tacktick so much... but it's like $500 after you buy the mounting bracket.
In any event, the most important consideration is that the compass must be easily visible yet not distract the skipper from his steering duties. That is why you see digitals mounted on the mast, below the boom, and magnetics mounted high on the dashboard as close to eye level as possible.
PS...Another option is to purchase a simple, lightweight handheld GPS... the Garmin 76, for example. Not a chartplotter. And either strap it to your wrist or mount it on the dashboard at eye level.. then set the largest display(two features) to show course/heading and speed.
Ross
Jun 15, 2004
14,693
Most of my sailing is within sight on land and just knowing the bearing of a landmark is all I need most of the time. If a fog rolls in the game changes and my compass helps to guide me to that landmark or nav mark. I believe that all boats should have a fixed mount compass.
Jun 14, 2010
307
Thanks for all the great tips!! I especially like the oh-so-cool digital tactical unit but at $500 (more than I paid for the boat!) it is a bit out of my league.
Joe is right - a handheld is not suitable. I maybe should have mentioned that my main objective is maintaining a heading and determining wind shifts with more accuracy. Maintaining a heading with respect to a landmark on shore is difficult while hiking out as it is hard to be sure you are sighting parallel to your course; sighting over a fixed point, e.g. the bow, also is inaccurate since you are sighting at an angle and therefore the bearing to a point on shore constantly changes. And large stretches of the shoreline are fairly undifferentiated at a distance making it hard to find a good easily identifiable point on shore. I have been using a combination of sighting on fixed landmarks and using my telltales to stay on a constant heading with respect to the wind, but it is hard to tell when I am being headed or lifted and whether the average wind direction is veering or backing with much certainty.
I would like to eventually acquire a GPS for the boat -- that would make it easy to determine leeway and current by the difference between heading steered and course made good -- but a decent boat-mounted magnetic compass will cover my needs very well, I think. The detachable model linked by RBone might be a good bet.
Thanks again!
Nov 9, 2008
1,338
I saw a couple on Ebay this morning. They seemed to be very reasonably priced with a "Buy Now" option.
