Companionway slides
Brent25
I am currently restoring a 1983 MacGregor 25. The wooden slides for the top hatch and companionway need to be replaced. I would welcome any thoughts on wood versus plastic/vinyl. Where to purchase these items or on the best way to build them. I realize this is a very open ended way of asking this question, but I am looking for my best options.
Thanks - Brent
O
oreana1234
I have the Idasailor rails, they wont cut you and they are much better to kick with bare feet.
Jul 7, 2007
79
Macgregor 222 Eau Claire, Wisc. Lake Wissota
I used plastic wood decking from my local DIY store. You can get it in different colors and no up keep. Regular wood working tools and skills. Cost was about $20 for enough to do top and companionway.
295
1970 Venture by Macgregor 21 Clayton, NC
While I was lucky and got some teak for my hatch slides, they are quite easy to make. While a dado blade or router makes the job easier, you can cut the rabbits that overlap on the slides of a the hatch on a table saw. You can make the required cuts in less than an half an hours. A little longer if you measure twice cut once. Several time that if you cut once measure twice.
Aug 26, 2007
90
Macgregor 25 Santa Barbara, Ca.
Speaking of Teak,,, I had heard that if you go to a Kabota tractor dealer, the crates that the tractors are shipped in are Teak and they give them away. Worth a try for some free boat parts.
Aug 26, 2007
90
Bandit: The slides are nice looking. Did you make the grab rails too? I like the shiny finish. How did you achieve that.
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
Yes, all were made and finished the same way.
I like the fake wood because it is full size, when they state that it is 1x4 that is what it is. I think they call it 5/4 If you look for real wood.
All sanded with 600 and then min-wax red mohagoney sealer-stain and the top coat is spar varnish.
Hint: Sand off fake grain before doing any work, it's way easier with a belt sander on the plank then holding each piece and doing with a jitterbug.:doh:
Rick
Sumner
Jan 31, 2009
5,254
http://i361.photobucket.com/albums/oo57/Tmebandt/IMG_0529.jpg
I used fake redwood decking material from Home Depot.
Those............
.................. look great and the boat............
.............itself is great looking.
I couldn't quite make out...........
............. these gauges and would like to know what they are and also could you give us the story behind this......
................ picture.
Thanks and I added you to my...............
http://purplesagetradingpost.com/sumner/macgregor/macgregor-links-1.html
.......................... links page, hope you don't mind,
Sum
Our Mac Pages
Mac Links
90
I am impressed. Thanks for the hints. SOOOOOOOOOOOOOO the last pic?
Jun 3, 2004
1,863
Oh that picture--
Not my boat, Just a reminder to keep the boat tied to the trailer at all times. I don't rembember the entire story but the ramp was from hell.
The good news was the boat was just scrached up a bit after a long slide as I recall (you might be able to Bing it.)
The gages from left to right---
Depth meter--Keel drags at 5 feet.
Knot and Log meter--Have seen 6 knots
Aparent wind direction--sender broken while being moved in a storage yard with mast down, now just use a windex.
