Companionway Board restoration
19
- - Shell Point, Fl
Learned a little lesson this week on repairing the surface of the laminated Companionway Boards..... Don't use a sander!! The teak laminate isn't very thick. And if they are covered with Urethane or Varnish it soaks into the full thickness of the outer teak. Sanding doesn't do any good. I went right thru the thickness of the teak to the next layer. Oops! Next night was planned to do the cabin floorboards. Used a paint/varnish remover. Much better!! These boards are a laminate too. Used the remover twice on each board, cleaned them up nice. Just a light touch of the sander and they look good. Will probably have to paint the companionway boards white. Not being able to get all the old varnish out of the laminate makes them look really aged.
sr1029
Jun 20, 2007
15
- - Sadler Point FL
companionway boards
I replaced mine with Lexon, lets light in, looks more modern, nice..
Sep 12, 2007
19
- - Shell Point, Fl
companionway boards
I thought of that too for a future project to clean up the area. And it would match the sliding hatch.....
