Companionway 3 piece door
paddyk
Oct 5, 2007
1
- - Miami
Need to replace original wood hatch door, 3 piece. Any idea where can get one. Would consider a plexiglass or whatever it comes also. Any ideas, would gratly be appreciated, thanks a lot.
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
Make your own
Get a piece of 5/8 inch plexiglass from a glass shop or hardwear store leave the protective film on it. If ther3e is no protective film cover it with the blue masking tape. Get a fine blade for a circular saw measure and cut the glass. Don't forget to cut the slats between the middle, top and bottom at a 40 degree angle to prevent wagter entering the cabin. When you measure the glass dot't forget to add the width oof the blade doubled to allow for the space lost as you cut it into thirds. Then all you have to do is add the hardwear for the lock./
