there could very well be an issue with the neighbors boat that is causing you the problems, but let me respectively say, that it could very well be your own boat causing the problem.... or a dock/marina electrical issue... but no matter where is coming from, it is
your problem until it is identified and fixed.
there are ways to test this and the procedure can be found by doing a search on the internet.
as im sure you know, hanging more zinc on isnt the cure for the problem, but it will buy some time until you find the problem.
the connecting wire for the anode should attach to the engine... which theoretically should take care of the prop as well.
but even so, it is my belief that with the prop out there all by itself and without any zinc on the shaft, you could still have some residual electrolysis/galvanic corrosion issues there, even though the majority of it is being attracted to the large anode hanging over the side of the boat.
it may actually depend on how bad the problem is.... which can be done by testing with a multimeter.
this is just one of many sites... I just chose it at random, so feel free to find a better, more informative site that you can learn from
