Hello everyone,
This is a continuation of my attempt to solve the problem of my vari-prop blades being stuck and unable to change pitch.
I pulled apart the combi enough to separate it from the engine a couple of inches. I used a lever to get in between the engine and the combi housing and then was able to pull the combi aft a little bit at a time until I got it an inch back. Then I jumped into the water to look at the blades to see if their pitch had changed at all. Indeed, they had changed. I am able now to change the pitch of the blades by hand while in the water.
When I shift them so that they are pointing forward (as if you were
driving the vega forward with the engine), the entire combi housing
shifts aft along the drive shaft. So the blades are not stuck in the
prop boss, like I had expected.
The problem is specifically that the "sleeve" (part # 27-1 in the
parts diagram) is stuck in the combi housing and will not slide
forward or aft within the combi housing. The teeth had not gone beyond their proper range ofmotion. I mean that the two small shafts that have teeth on them in the combi (parts 33-1 and 28-1) are properly grabbing the teeth of the sleeve. It is just that the sleeve will not slide forward or aft within the combi.
So at this point, I feel like I probably need to get the combi out of
the boat so that I can completely pull it apart and see if there is
some broken part that is blocking the sleeve's movement. I suppose
that it is also possible that the sleeve is just stuck and could be
forced to free it up, but there's no way to know right now.
I've been following the instructions in the file named "Combi Instructions.ppdf, and I've reached step # 15, and I am stuck here right now. These instructions say to pull the prop boss and shaft aft by using a lever (which I'll have to do while underwater). This is supposed to pull the while shaft aft enough so that you can remove the combi from the boat.
I wonder if you have any advice about how to pull the prop shaft aft
other than just using a lever against the hull while underwater. Any
ideas or help would be appreciated. I'm so glad that the problem is
not in the prop boss so that I don't have to haul the boat out, but I
still need to get the sleeve to free up.
I'm here on the boat until tomorrow evening so I will be working on this until then. Then I have to go home for another week. So I hope I can get the combi out before I go!
Many thanks,
Kristopher Setchfield
(413) 210-9323
Many thanks,
(413) 210-9323
