When I bought Lyra, who incidentally has now been officially and
ceremoniously renamed Katia Sofia after two kids in Mexico. . .when I
bought her, as I was saying, I found the grease gun for the combi
under the stbd cockpit seat. I could identify it as the right
grease, not just by the the fact it was handy, but the little gob of
grease on the engine room floor was the same as in the gun. Don't
know what that is, so that's first question. . .what's the right
grease for when I run out? Second question is, since less than 800
miles of motoring later. . .I have another little gob of grease on
the engine room floor right under the Combi output. . .is that OK?
Oh, to define "little gob" say. . .good sized hens egg. And the
corollary question. . .how much should I pump in each time and how
long between offering it to her? Is there somewhere it "vents" so I
can see I've filled up whatever I should be filling up?
Change subject. I took out, cleaned and lubed the thermostat which
seemed intact and healthy but with a little black crud all over and
the engine now runs at a very steady 75 degrees with almost no
variation once warmed up. I will try to find a 60 degree
thermostat. Sources??
One last question. Can you change the cutlass bearing witout pulling
the shaft(s) out of the combi? Do you disassemble the prop?
Boy. I'm getting my money's worth this time. Thanks everybody!
Ken Preston, Seattle area.
