Hi all,
Just a couple of questions. "Overture" was retrofitted with a ZF, BW6
gearbox in place of the combi-drive using some less than desirable
engineering. The offset between the input and output shafts creates
some problems in aligning the prop shaft. I am trying to find the
best way to move the engine back to its original position, make the
connection to the gearbox and then to the prop shaft. I would like
to find out if the combi-drive has any offset between the input and
output shafts? If anyone has experience in modifying a Vega for a
gearbox, that they are willing to share, it would be appreciated.
My second question is a little simpler (maybe). Does anyone have a
rig-tuning guide for the Vega? Some the shrouds are loose and I would
like to find out how others have adjusted the masts
Many Thanks
Paul
V2926
Many Thanks
Paul
V2926
