Wish I could
Sorry, though I am a mechanical engineer, my unit was new in 1983 and I know lots has changed in the 12v reefer world since then. My unit has been through a number of upgrades including a new cooling fan and new electronic module, but it has worked faithfully for about the last 10 years with no attention necessary (knock on wood). The last I worked on the unit I found a local service company in Baltimore that had a great deal of experience with AB, and had everything I needed for servicing the unit on the shelf. The question of replacing the entire unit came up at the time, and they had an entire compressor unit on the shelf for what I thought was an astoundingly low price. Their comment at the time was that the compressors never break. Fortunately, they were right. Simply replacing/upgrading the electronic module did the trick. I have the AB trouble shooting guide for my unit, provided by AB with the service T and pressure/vacuum gauge they used to sell to any do-it-yourselfer. But, because my unit dates to the dawn of AB refrigeration, I doubt if the information I have from the factory would be of much help. I will check it this weekend and see if the guide describes the symptons you are experiencing. If you had not measured the voltage already, I would have guessed you were seeing a low voltage situation, but given what you have posted, I am guessing that the compressor has an internal electrial fault that is heat related. Hearing that you have a freezer compressor doing the same thing after several hours of use makes me wonder if the heat in Key Largo this time of year is a factor. Are the units mounted in a hot location? It is hard to believe you have two units exhibiting the same symptons without them experiencing some common problem (low voltage, high ambient temperatures, etc.)Surely somebody in KL works on these things and is willing to talk it over with you. They may even have replacement compressors for a good price like the guy in Baltimore. I'll check my info and get back to you next week.
