W
Will
I've got an older R-12 cold machine that's running well but doesn't seem to want to stop. With the thermostat dial set as low as it will go (without turning the machine off), it still runs for long periods of time, and keeps temps low enough to freeze water in the bottom of the cooler box. It shuts off occasionally, but seems to run a whole lot more than not. Any suggestions would be most appreciated.
