Some time ago there was a post about coffee makers and battery power usage. Some say to use a fuel stove to make coffee since it uses so much power. I recently purchased a Kill-a-Watt meter and tried it on my Mr. Coffee machine this morning.
Here are the results for 6 cups of coffee:
Power from coffee maker - 930 Watts.
Time for 6 cups to brew - 6 minutes.
Power usage was 90 Watt-Hours to brew the coffee for the 6 minutes and then as soon as the coffee was done brewing the internal thermostat kicked on and reduced the power consumption to 2 Watts (got to keep the power light on).
The power then cycled on and off to keep the coffee hot. Power levels to maintain the temperature of the coffee was very low!
After 15 minutes the total power consumption was 100 Watt-Hours which included the brew time.
So what that means for the battery if you have an inverter:
Brewing 6 cups will require about 7.5 Amp-Hours from your battery - probably 8 when you consider the efficiency from the inverter.
Maintaining the coffee hot will require about 1 Amp-Hour every 5 minutes.
So, go ahead and get that inverter for your coffee - the power aint so bad after all!
