dajspi
removehtml]Hello All,Newbie here... be gentle... I am assuming this forum is for advice, insight, etc. as it applies to sailaboats. I recently purchased an older boat, 73 Catalina 27. I have some work ahead, and could use some insight has I try to prioritize and research potential projects.One task is the cockpit. The original Atomic has been removed and replaced with a outboard/bracket setup. Also a new wheel was installed that replaced the original tiller. Looking at the external instrumentation(knots meter/compass/old speakers) imbededded on the cabin it becomes redundant with a gps and compass on the wheel. I would like to remove this stuff, however I would have gaping holes all over the place. Has seen/used/recommend used marine paneling to cover the cockpit walls? I'm even considering Home Depot plastic beadboard might have a decent cosmetic finish. or am I stuck with the Fiberglass, sand and paint route? Thanks.Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
