cockpit table for H-27s
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Apart from the why it's missing in the first place, does anyone know where I might go to get a replacement galley table for my 1990 H-27? When I purchased it several months ago, the only thing there was a little, triangle-shaped surface that you couldn't put you army ration can on (PO knows nothing about its whereabouts either). There is a good under-bracing mechanism in place but I need a "real" table for my crew (family). Any ideas?
I
IslandJack
got the original equipment
on the same boat. Since the table folds up against the forwrd bulkhead the top doesn't show, just the bottom. a formica type top with teak veneer on the bottom would probably look about like the original when it was folded up...or a coffee table top might work...I'm assuming your talking DIY and not off the shelf stuff. Jack
