john bonner
this maddening, 82 cat 30 with edson wheel steering, i have used permatex to seal around the insides of the cockpit drains, from below there are no apparent leaks from the cockpit drains or tubing, however,when there is water in the cockpit there is a slow but continuous drip from the steering assembly attached to the rudder with no seen source from above. any suggestions as to possile culprits and crafty solutions? thanks.
