Cockpit hatch slides?
Aug 7, 2015
118
Oday 34 previous, O’Day 40 current Annapolis
Has anyone replace the plastic slides that the cockpit hatch slides on? They are currently held in w/screws that can likely be pulled out, but impossible to replace w/o removing the wood work. Thinking of using HPDE or an acrylic but I don’t know if these can be adhesively fastened. Any thoughts appreciated.
May 30, 2006
365
Oday 34 Chesapeake Bay
My ‘81 34 has teak slides which are screwed in. Not too difficult to get to. Would be nice to replace mine as well, they’re a bit shabby and are hard to slide at times.
Mar 24, 2012
74
O'Day 40 BC Coast
You can't glue HDPE because it's too slippery. That's why the originals are screwed in.
My slides are cracked, maybe from temperature changes, but they still work well.
It would be a big job to remove the teak covering them if its just for the aesthetics of having cracked slides.
Sep 24, 2018
4,095
Catalina 30 MKIII Chicago
I know this is a different design than the 25 I had but Ive discovered that the wood track wore away over 50 years and this in turn caused fiberglass to slide on fiberglass. The fuzy side of velcro on the hatch fiberglass was the quick fix
Aug 7, 2015
118
I was afraid that the HPDE could not be adhesively attached. My slides have broken & shouldn’t be too hard to remove. Maybe wood is a better choice & I could possible screw them into the side…..hmmmm
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
I have used UHMW tape that is available in various thicknesses from Mcmaster.com. I know that 3M #77 spray adhesive works. Spray it on, let it dry. Spray again and install while wet and slippery.
Likes: Timm R Oday25
Aug 21, 2020
41
Oday 40 Dalhousie Yacht Club
Replaced mine last year. Took advantage of having to remove the teak trim and refinished it while it was off. If I remember correctly I used 1/2" thick? x 3/4" wide? strips of HDPE. Inexpense project, but labour intensive.
As far as I know, nothing will stick to HDPE. I think any fabrication of HDPE is fused.
