Cockpit floor delamination
tarbaj
The cockpit floor in my 87' Catalina 25 is in obvious need of a rebuild as a result of delamination. The floor deflects alot when you walk on it and it sounds hollow when you tap on it. Can anyone give me an idea how much this should cost to have professionaly repaired? I've done some research and the materials for a balsam or plywood floorboard replace should run about $200. How many hours of labor are involved and whats a typical hourly rate? Thanks!!
C25
tarbaj I recommend that you ask the question at the related link. Stu
