Cockpit drains go where?
Jul 30, 2013
56
Hughes 25 Burlington
I see water under the drain.Where does this water go? If it is to the bilge, then I can't seem to drain it.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
They should go to thru hulls on the hull, don't want them discharging into the bilge.
Good looking boat!
Feb 17, 2006
5,274
Mine drain out the transom, one on each side. There are two hoses connected to the drains, they do not pass, GO, they do not collect $200. ;)
You may have a leak in one of your hoses. You might want to put a water hose on the drain and start running water to see if there is a leak.
Oct 26, 2005
2,057
Barnacles like thru hulls. You could slid a plumbing snake down each to see if they're clogged.
If the thru hulls are below the waterline the hoses will contain water.
Feb 17, 2006
5,274
I failed to mention that my drain outlets are above the water-line.
Mar 30, 2013
700
Mine have a little bit of a dip in the hose that holds a little water (and other crud). It's on my list of things to fix.
Try running some water through them and see if they drain overboard like they should.
