Finally got my 26S home. The boat was full of sea water so I wet vacced that into the cockpit. Then I noted the cockpit was not draining. I stuck a wire up the hole from the outside. I got it all the way through, but still would not drain. I did note little bits of yellowed plastic on the ground. My question--did these boats have a check valve or something that may be stucK?
I finally wet vacced the cockpit....
