cockpit drain valve
David Jones
Any advice on replacing the drain valve in a 1977 Cat 22. Mine looks very rusty. How to get the old one out and what type to put back? Thanks
David
Why have one
If this valve is left open all of the time Why is it even necessary? Why not do away with the valve altogether?
stevelrose
Does it drain below the water line?
If it does, you need a valve.
David
drains below water line
Yes it drains out under the boat. My question is if I have been leaving this valve open all of the time,why do you need a valve?
stevelrose
just in case....
... the hose breaks. With no valve there, you've got a big problem. In general, all thru hulls should have valves.
