I went down to check on the boat (on it's trailer) on Friday and found two unpleasant and potentially expensive surprises.
The first one was a fairly easy initial fix - I just had to drain about 50 gallons of water out of the tarp which was sagging into the cockpit. That one may have bent a stantion a bit but I'm not sure it's not an optical illusion as the parking lot is not quite level.
The second one is probably going to be more trouble - part of the rim on the brass insert on the cockpit drain has disappeared and I now have some of the core showing. So, my question is, how do I get the insert out (will cutting it with a hacksaw let me compress it and pull it out? And, more important, what do I replace it with?
Here's what I found:
Any advice on how to fix this would be greatly appreciated!
Thanks,
Thanks,
