Okay... whoowee ... so excited to explain this, my marine engineering knowledge!
You need a loooong clear piece of plastic hose. At least 8 meters long or in "American" at least 25 feet long. Clear because you need to see through it!
Take said hose and hold up the two ends.
Fill said hose with suitably coloured water... use red food dye.
Now without loosing the water secure one end of the hose on the front of the boat above the water line... use some duct tape or similar.
Now carefully drain the water out of the free end of the hose until the water level on the secured end of the hose matches the water line... I would go with the center of the boot stripe if you have one.
Now... with out loosing any water out the tube... you can walk around your entire yard and mark the water line level on your garden walls, house wall, car, shed... the neighbours dog if he is big enough... you get the idea.
Go to the stern and secure the hose on the transom... you can level hull forward and aft.
Go to midships port side or stearboard side and you can level the boat athwartships!
Simply old school technology since plastic see through hose has been available!
Now try this on a 300 meter long ship!
