Cockpit Cover
Jul 15, 2023
1
Oday 17 Lake Memphremagog
I am looking for a company that would make a waterproof cockpit cover for my 1960's 17 ft Oday daysailer sailboat. Please help! Also, does anyone have any experience with using a solar panel connected to a bilge-pump to have bailing as needed for one's cockpit? Just wondering if that kind of thing would work.
Thank you!
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
Can't help with the cover, but a small solar panel, deep cycle battery, and a small bilge pump with a float switch should work perfectly. The hardest item to get is probably the battery if you don't want one grossly oversized and expensive. I would look at replacement batteries for emergency lighting units for a 12v battery with about 20Ah capacity.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Thank you!
Welcome to the forum.
I have to say, rather than ask here for a cockpit cover, if you googled it you'd find the first hit is for an O'Day Daysailer cockpit cover, here:
The Sailors' Tailor Inc.
$370.
Geez!
jviss
Feb 5, 2004
7,090
For the bilge pump, I recommend a small LiFePo4 battery, and a small solar panel you can easily stow and deploy, and a small pump and switch combo.
Nov 8, 2007
1,607
For the cockpit cover, the folks here at SBO did a great job on a custom cover to my design for our h-27. I'd give them a call.
Add a small charge regulator to your solar bilge pump design or your battery won’t last very long
Likes: jviss
