Cockpit cover for h23
Lee Y
Jun 5, 2004
43
- - Muskegon, Michigan
Does anyone have a good photo of a cockpit cover for an h23? I want to make one but need some design input. Our boat gets sticks and leaves in the cockpit that end up plugging the drain.
Thanks for your help
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
Do you have a centerboard or a wing keel?
If you've got a boat with the wing keel, your best bet is really to add drains that go straight out the transom. The stock drain is too small and a good way to take on water if the rubber hose leaks. It's a holdover from the centerboard, which had control lines going to it through the cockpit drain and around a block mounted under the boat.
