Coating a cast iron keel?
Jul 28, 2013
126
Hunter 34 Holland, Mi
I have a Hunter 34 with a cast iron keel that needs to be cleaned and coated. I have heard a lot about interprotect 2000 and was price searching and came across this product and wondered if anyone has experience with it?
http://www.bottompaintstore.com/tuf...-p-9473.html?gclid=CKDglo3e_boCFYNaMgodTlcA4w Any input would be great. I don't mind spending less but if it is not a good product I didn't really save anything. Thanks.
Jan 14, 2011
243
tanzer tanzer 28 bathurst nb
I used interprotect, last year keel is still good as new after one season
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
It's all in the prep anyway..
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Did my keel with Interprotect last Spring. It's vitally important that the preparation is done properly. The surface has to be ground down to bare iron (or media blasted),and the first coat of Interprotect must be done before any oxidation appears no matter how slight. Its a bear to get the old coating off. Multiple coats of Interprotect need to go on within hours of one another, and the first coat of bottom paint has to follow while the last coat of Interprotect is still a bit tacky. It's not a one day and done type of job.
Nov 24, 2012
586
Success is not only determined by bright metal but coating it almost immediately with a primer. I believe the primer interlux uses is primocon (sp?)
I have successfully done my keel in 'patches' vs a complete keel. So far so good
Jul 28, 2013
126
I plan to have the keel blasted clean in the spring and get the epoxy coating on right away. You are all correct that prep is very important. Thank you for your comments. It sounds like the Interlux products are widely used. I would really like to know the difference in the two epoxy products. Thanks.
Nov 24, 2012
586
There is also a product called VC-tar. Both yards I've been in use Interlux exclusively.
DougM
Jul 24, 2005
2,242
I have used primocon for a temporary patch job and it does a remarkably good job. When I redid the keel completely, that was the most difficult portion of the removal process. I've got to say its at least a good stopgap.
Mar 1, 2012
2,182
I've had two boats with cast iron keels, and have had very good luck with Coal Tar epoxy. It's used on the offshore rigs, and by the CG on buoys.
Stinks while being applied, but has held up very well. I used the Interprotect 2000 on the hull , but not the keel. Just redid the bottom after several years (6 on the keel) with almost zero problem on the keel.
Jun 21, 2004
21
Hunter 34 Cape Coral, Florida
I have the Hunter 34 too and i used VC Tar and that was 3 years ago. It has held up very well and is self leveling, so it came out very smooth as well. This is the second cast iron keel I have done with VC Tar and both are still looking good and free of rust. Surface prep is everything! I put 4 coats of VC Tar on. The last coat was coated with good bottom paint(Super Ship Bottom) while still tacky. I'm in SW Florida in some of the saltiest water on earth.
CS 27 - Nova Scotia (Pugwash)
If there are only a few rust spots..like mine...I gave a test using rustomlium paint.. Covered this with undercoat.. Looked good after a season
Jun 9, 2008
1,792
- -- -Bayfield
I don't think V C Tar is available anymore. Interprotect 2000 is much better as you can put on more than one coat in a day. Time between coats depends on the ambient temperature. It is explained in their product info.
Pearson 26W Marblehead
cast Iron keels
Im sure there number are a number of systems that will work. What I did was : first I scraped off what was left of the original fiberglass coating on the keel. next I washed the keel with lacquer thinner to remove any residue. Then 2 coats of pettit 1 part rust inhibitor next was 2 coats of west system epoxy. and finally 2 coats of ablative bottom paint. after a season in the water things are looking good. Dont forget its in the prepwork
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
have a lead keel but over ten years ago ground to bare lead mostly with a belt sander. sand again immediately before coating to remove any oxidation (lead is very reactive and will oxidize almost immediately). Then 2 coats of West system epoxy. Then two coats of interprotect 2000 as a base for the paint. Then while tacky apply the paint. Haven't had any paint peeling issues on the keel since. Boat is out of the water now for a paint job and it still looks good.
Feb 6, 2013
437
Hunter 31 Deale, MD
I did this job a few months ago. I scraped off the old paint; an easy job since it was peeling off in sheets anyway. I cleaned the keel using a compressor and die grinder with a wire wheel. Not nearly as messy as blasting.
Jul 28, 2013
126
Thanks great for all the great input! I still have plenty of time for research since it is cold and snowy already. Thanks again.
zeehag
Mar 26, 2009
3,198
i learned that my iron keel was perfect after 26 yrs unprotected and no haulouts.
once i hauled it, i figgered, ok was good since 26 yrs , lets leave it. when i hauled to place into hank mckunes yard(--he built it--took it in trade against my yorktown 42 i was having him build in 1990....) we found an inch was rusted...one inch everywhere, allover keel. it lost one inch of iron to being unprotected. (one inch from each side, as well as from leading and trailing edges, etc...)
if i were you, after this experience of my own boat, i would find a nice barrier coat for iron keels and use it. enjoy your boat.
