All,The major difference between CNG and propane is the CNG is lighter than air and will escape if there is a leak. Propane, as everyone knows, is heavier than air and can collect in the bilge or other low areas and may cause and explosion. That is why propane installations require a remote control cut-off solenoid at the tank and a "sniffer" to detect fumes and CNG does not. CNG is readily available in the States. If you are to cruise offshore or to Mexico, CNG is generally not available but propane is plentiful. CNG stoves are available from Force 10 and Seaward Products. The difference between propane burning stoves and CNG burning stoves are the burner metering orifice sizes. Force 10 and Seaward sell conversion orifices to switch their stove between one fuel or the other. CNG is the same gas piped to your house but compressed into the CNG bottle using a special compressor. BTW, on my Catalina 38, I use CNG.Rodney KiddC-38 #297, Flying BearSF Bay
