Dennis
I had the rule of closing through hull valves reinforced this weekend. We were sitting in the cockpit at the dock when the bilge pump came on. This is unusual since my bilge on my 91 30T is always dry. Anyway, after investigating I found my raw water intake hose at the engine leaking. I removed it and cut the end off and tried to reattach. Forget it. The hose kept disintegrating. This seems like a short life for an expensive hose (all fresh water too).Has anyone else experienced this? I was going to replace this hose with an automobile heater hose but found out you should have a hose that can withstand the pressure if the hose is blocked or partially blocked.
