Hi all,My wife and I went sailing on Veteran's-Day-Thursday and had to sail with mainsail only (the Florida fall winds were sustained at 20 knots). I noticed that, when tacking, I had to bear way off the wind, when settling into the new tack, in order to get forward motion out of the hull and accelerate onto the new tack. If I tried to cheat closer to the wind (say, at a angle that would have easily worked for jib and main working together), the boat pushed sideways and incurred major leeway--- I mean enough that you could see thrust/current from centerboard side-wash on the windward side of the boat.Is there a way to counteract this/make the boat point a little high while coming about? Is my rudder not properly downhauled perhaps? I'd read that larger Hunters (the 23.5 and 240) have slight tracking problems when their rudder blades are not set down at a fairly precise angle. Also, my centerboard was let all the way down---but I daren't change that in this sort of wind???Has anyone "played" with rudder angle/downhaul on the 170? If so, does fudging with it make a noticeable difference? How about raising the c-b a bit (or more)?By the way, any more wind Thursday and our 170 would have been all the way up on one rail (we ALMOST had to put the first reef in the sail), but my wife and I both sat on the high rail/gunwale and it was a perfect day. Great crew ballast. I'm starting to come around (used to pine for a far heavier c-b, but I'm getting the feel for her).Regards,Mike G.'99 h170
