Well, I went to take the boat out and it seemed OK for a while until I increase the RPMs. It then took on the unmuffled sound like when the intake valve is closed. I checked the valve and continued. After I had gone out, 15 minutes later my high temperature alarm sounded and I shut down the engine. I checked the valve again. I figured the intake had gotten clogged and decided to go over the side and check. (The correct way would have been to shut the valve, disconnect the hose, then open the valve to see if water flowed freely.) I didn't feel anything when I put my finger in the through-hull while in the very cold water, but when I got back to the dock and diconnected the hose I found a fish tail protruding from the fitting where a minnow had gotten sucked into the intake. I took a bit of effort, but the fish was removed, the hose reconnected, and the engine run successfully without overheating.
