Billy,
Just look at the drain hose on the sink bottom. Simply follow this & you will eventually find where it ties into another line or, see the valve. Mine is straight below the sink. I have a 1980 C30. Your year may have a different hose run and/or valve location.
When you do find it, assume the valve is original & maybe a rising stem gate valve. These are notorious in failing over time. It is probably closed, which is a good rule to practice for all thruhaul valves if the boat is left unattended. The biggest problem is when the stem breaks inside the valve so, if turning the handle does not close or open the valve. They do however fail mostly in the open position. If this is the case, any valve you change out in the future should be a Marlon or equal BALL valve, never a gate. It should never seize & it considered a "positive shutoff" valve whereas a gate is not.
Another thing to keep in mind with gate type valves, when opening them, first open the handle all the way open. The trick then, is to turn back a quarter to a half turn. This way the valve seat should never seize up & the stem shouldn't break over time. Remember older valve material does not like salt water the most.
Use this method on all your gate-type valves at home also, under sinks & all plumbing valves.
CR
