clogged drains
robert sarpy
The sink drains on my 376 are draining very slowly, and seem to be clogged, does anyone have a solution for this problem, please help.
Peggie Hall/HeadMistress
Give a good dose of C.P.
It's a bio-enzymatic toilet bowl, sump, and drain cleaner that "eats" grease, hair, soap scum and other stuff that clog drains (and btw, it also kills odor on contact). Available from the online store here (and from BOAT/US if you can't wait for mail order). You may have to close the seacocks and let it stand for a day or two in drain that are running slow...but a good squirt down 'em once a week will kepp 'em running free and smelling good. And as the name implies, a squirt down the drain keeps sumps clean and smelling good too. Whatever you do, do not use a chemical drain opener...it will destroy your hoses.
Jay Eaton
Slow Drain
We have a new H380. The sink drain in the head empties very slowly. The through hull for the drain is under the boat and the drain hose is not very straight. All this inhibits the proper effect of gravity on the drainage. JAY
