I remove the masthead for my C-22 to clean things up an have a closer inspection of standing rigging condition (most of it will probably get replaced).
The clevis pins for the sheaves came out with no issues, but the pins for the forestay and backstay are both stuck fast with bimetal corrosion. I sprayed a little PB blaster and let it sit for awhile but they still aren't backing out with a punch and mallet. I don't want to hammer on it very hard because breaking the casting will be $150 to replace.
Two further steps I could take, I can submerse the whole casting in a bucket of Aluma Prep (an acidic cleaner for welding aluminum) which will dissolve the corrosion residue. I can also heat the casting around the pins so a little expansion might give enough wiggle room to back out the pins.
Last resort, because drilling stainless is a PITA, drill press.
If anyone has any suggestions other than what I mentioned above please let me know. I'm in no rush and don't want to do more harm than good.
