Cleats for perforated toe rail
SFS
Aug 18, 2015
2,082
Currently Boatless Okinawa
My H31 has a very nice perforated toe rail, and I really want some mid-ship cleats. Has anyone found a cleat that mounts to a perforated toe rail? My searching has only yielded this one, and it looks pretty flimsy:
http://www.defender.com/product3.jsp?path=-1|2259971|2709020&id=80333
I'd like to find something more substantial, and would prefer to stay away from track mounted, unless I have no options.
Jun 11, 2011
1,243
Hunter 41 Lewes
I had that cleat on my Hunter 25.5 and it's on my friends Tartan 31 that we race on Wednesday nights. Not flimsy, simple. It works well and is very easy to mount and use. I worry it will tear the toe rail off, not that it will fail.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
That is exactly the one I am looking at and I am thinking since it for the spring line it will do just fine it is mounted with a 3/8 bolt
Beneteau 323 Annapolis MD
I had that same situation on my B323. I raft everyother weekend, so really needed that mid-ship cleat. I got 2 OEMs and bolted them to the deck. /// Otherwise, i've seen cleats thru-bolted to the toerail with a slab of wood on each side of the toerail for reinforcement. Another way would be to use one or two pieces of genoa track to sandwich the toerail in whatever length you think you'd be comfortable with. /// You could bolt a cleat vertically to a pice of wood, which would then be bolted horizontally to the toerail when needed.
Oct 6, 2007
1,096
Hunter H30 1982 Chicago IL
I've been using exactly that mid-ship cleat with my single-handed docking spring line for about four years now. Surprisingly sturdy. No problems. However, I do not use it for my long term dock spring lines. They are attached to a mid-dock cleat and run forward to a bow cleat and aft to my genoa winch. The reason being that the fold down toe-rail cleat is attached with a single bolt and nut which does allow it to move (rotate) a bit on the toe-rail and I fear that back and forth movement of the boat could loosen the nut (even a lock nut) over time with long term docking. So, IMO: Great for short term use - coming into dock on a springlike or rafting up for an afternoon. Not the best choice for long term docking.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have those cleats on the toe rail of my B323. They are quite substantial. They have served me well for spring line attachment for a number of years. I really haven't had a problem with movement due to the boat surging. The toe rail itself is strong enough and because it is through bolted in several places along its length it helps to spread out the load. There is is a rubber spacer that folds over the top of the toe rail and extends over the bolt hole and that also dampens the shock load slightly.
May 24, 2004
7,140
CC 30 South Florida
Years ago took an "L" 1/4 "steel brace, cut a piece around 5" long, inverted it and drilled some holes to attach to the inside of the rail on one side and drilled other holes to fit a cleat down on the other side. Smoothed the edges and painted it black for rust protection and to blend in with the rail. It was fit in an h27 right behind the starboard shrouds which afforded protection from stubbing the toes. Only needed one side. Survived a couple of hurricanes and plenty of foul weather being used for spring lines.
Apr 8, 2010
2,032
As others have pointed out the C. Sherman Johnson cleats are well engineered and strong. We have been using them on the perf. toe rails on our boat for almost a decade. Good product. They make this in a track mounted model and a deck mounted model as well.
Actually, I have never seen anything from this vendor that was flimsy.
Loren
Dec 25, 2000
5,859
Wow, nice installation. Did you need to treat the toe rail with alodyne or some other stuff to prevent corrosion ???
Hi Ken, no treatment needed as of yet. No evidence of any corrosion either and that has been more than ten years ago. Maybe someday.
Hunter Marine Customer Service advised me at the time that the toe rail is especially strong and would be the best solution for a mid ship cleat. I wanted something at least as strong as the bow and stern cleat as it would be the first and last point of release from the dock.
Likes: limbodog
Dec 25, 2000
5,859
Hi Ken, you are most welcome.
Two long-time Everett sailors you may know, Bob Barker (still in Everett) and John Lund (moved to Anacortes). We meet every Wednesday evening at Scuttlebutts' for Skipper's night. Usually start during happy hour with open topics of interest. Come join us if you want. Always a hoot.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Terry, that is great installation. On either side of the cleat and into the toe rail you have what looks the the head of a stove bolt. What are they?
Dec 25, 2000
5,859
Hi Richard, those are the carriage bolts that are part of the deck-hull joint that secures the aluminum toe rail. They are spaced about every six inches for the length of the boat's deck-hull joint.
Aug 16, 2009
1,000
Oh, OK. The H31 used countersunk flush mounted phillips head bolts.
Likes: pateco
Dec 25, 2000
5,859
No idea why Hunter used different fasteners. Plenty strong though. And no idea why they built the boat without a midship cleat. As a solo sailor, near impossible without them. A breeze with them.
