Folding Cleat Works Well
I needed cleats for spring lines on my 33. I bought a pair of folding cleats for the side decks mounted just about perfectly amidship. The great thing about the folding cleat is that it is out of the way when not in use. The bad thing is that it needs to be recessed in the deck. I used a large steel backing plate through bolted to the cleat base to spread the load. Rather than live with these ugly plates in the cabin or re-do the entire headliner, however, covered the plates with single piece teak boards and then through bolted the cleats on through these. A recess was routed in the side of the teak boards next to the plate so that the plate is invisible and I rounded the corners with a router before mounting. It looks great and in 2 years I have had no leaks, stress cracking or other problems.If I had it to do again, I might consider through bolting the steel plate and then routing or drilling out recesses for the bolts in the teak so the through bolts are invisible.
